Results 1 to 10 of 52
Thread: Starting off just like I left last season :(
    scootchu is offline Registered+ Thread Analyst scootchu 0
    Red face Re: Starting off just like I left last season :(
    Well good thing you are paying attention because I'm not.
    I checked my water again today.
    FC >10
    TC >10
    I was looking at the 20 for Bromine on the test strip chart
    PH is around 7.2-7.4
    ALK is around 130
    I don't have a Calcium test, just a hardness test in which I get low
    I have just about got all the acorns out. It's tough when you cannot see them.
    The Robo-Kleen has been running and bringing up pollen and crud.
    I put a stocking on the skimmer basket which has had to be cleaned twice in 2 hours.
    I put another 3/4 gallon of bleach in.
    Thanks for sticking with me.
    Default Re: Starting off just like I left last season :(
    I just ordered the Taylor 2006 kit today. Hopefully it will help me get a hold of things a little easier.
    stma is offline Registered+ Thread Analyst stma 0
    Poconos, PA
    WaterMom: But at what point do you start considaring the filter/sand as the culprit ??/ I'm on day 11, and 23 gallons of bleach later. i have seen zero change in my pool water...still green and cloudy..so much to the point I have not vacuumed yet....brushing, yes...but I can't see past 18 inches from the top....
    I'm wondering if the WalMart sand I bought (which was 1/2 the price of ANYone else locally) is actually my problem ?? (the old saying, "You Get What You pay For" is starting to ring true for me ???
    When did you install your new sand? If it's new I do know that it's not as efficient as older dirtier sand at removing particles.
    In my world I have added a total of 12.5 gallons of bleach over the last 2 days. The filter is on 24/7 and the robot is running too.
    I still have cloudy green water, but I can now see faint image of the yellow robot at the bottom.
    The filter isn't getting bogged down anymore and the skimmer stocking really helps with the little stuff.
    On avg what kind of timeline can I expect to see improvement and more of the bottom?
    It's a 17,000 gallon 48" pool.
    There isn't a timeline. Every pool will be different. Just keep hammering it with bleach and maintain a consistent shock level without letting it fall and it will clear. I'm still wondering if you could be having any metal problems since you say you partially fill with well water. It wouldn't hurt to have a pool store check for metals in the water.
    It was from my neighbor's well and they had no issues with their pool with 100% of the water from their well and I know every pool is different, but I tend to think it's okay.
    If I can I will take a sample to the pool store and have it checked.
    Thanks again!
    Quote Originally Posted by stma View Post
    stma --- It is usually best not to jump into the middle of another thread because it gets complicated trying to help two people at once. I just replied to you in your other thread about posting a current set of water testing results. (FC, CC, alk, ph, cya). Repost that info on the other thread and also over there tell us if you bought pool sand or play sand. I doubt it is your sand. Let's continue on the other thread. Thanks.
  1. Taylor Kit Left out all winter
    By cooper in forum DPD-FAS based testing
    Last Post: 05-22-2011, 07:42 PM
  2. powder left from bleach evaporation
    By expose in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-17-2010, 03:38 PM
  3. Left pump out all winter in MO, dead now...
    By Sauce in forum Pool Equipment & Operations
    Last Post: 05-23-2007, 04:22 PM
  4. What to do with left over tiles?
    By SeanB. in forum General Interest
    Last Post: 10-01-2006, 09:40 PM
  5. left over pool chemicals
    By centexpool in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-03-2006, 09:39 PM
