Thanks for the tip. I had a 30ppm FC yesterday and my PH was 7.2
ALK was about 100 and my CYA was 70.
The pool water is bluish, but still a bit hazy. The bottom is clean of all organic materials. You can see the robot on the bottom with no problem, but the water is still not even close to crystal clear. I had DE somewhere, but cannot locate it. I will try to find it and/or buy some to put in the filter.
The pool store guy did try to tell me my sand was rounded and most likely needed to be changed and I could see how that would work in theory, but not in practice. I doubt 200 pounds of sand is going to tumble over and over like a rock tumbler and turn them into polished gems would it?
AND if things are a PITA enough the pump decided that the bushing between the impeller and the shaft was going to leak. I think there is a replacement bushing, but the shaft may be the cause and not worth trying to repair.
I added a small amount of clarifyer yesterday morning, but it didn't doing anything spectacular. I would really like to clear up the hazy water. The filter doesn't seem to be getting the tiny little particles out like I would like.
I know, I keep trying different levels in my pool to one day find out how to keep metals out the easy way.
