Thread: Hose for chlorinator
    Ohio,Canton
    Question Hose for chlorinator
    I replaced the hoses on my Rainbow chlorinator with clear vinyl flexable tubing. Will the chlorine have any effect on the tubing? I'm concerned that the hose may fail while I'm away. Has anyone tried using any other hose than the manufacture sells?
    Brookline, MA USA
    Default Re: Hose for chlorinator
    Vinyl is bad. It's not compatible with FC.
    Get what Hayward sells or Tygon 2075.
    You can get the latter at sidewindercomputers.com
    Hayward's saddle fiiting kit for Chlorinator includes about 2 ft of tubing. You can get it on line or in pool supply stores.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP
    38 SF DE filter, 1 HP Hayward Super Pump
    Raypak 350k BTU Natural Gas Heater and solar cover
    8 gal Liquidator with bleach
    Dolphin robotic cleaner
    Taylor k-2006 test kit
  1. popped backwash hose near end of hose
    By Gretzky99 in forum Pool Equipment & Operations
    Last Post: 05-22-2013, 10:30 PM
  2. how do I fix pool hose?
    By jdyell in forum --cleanup--
    Last Post: 09-29-2012, 11:10 PM
  3. Hose
    By jrv331 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-03-2008, 05:45 PM
  4. Need Help with a hose
    By IMherDad in forum Pool Equipment & Operations
    Last Post: 07-07-2006, 08:36 AM
  5. How to fix hose from leaking at end
    By nicole12 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-31-2006, 11:07 AM
