Results 1 to 10 of 31
Thread: First time test results...
    Default Re: First time test results...
    Good morning back! You can do both at the same time. I do both all the time with no problems. Just go with small additions and add them slowly to your skimmer while the pump is running, breaking up any large clumps. Then, wait a few hours to let it circulate and then retest and redose as needed until you get them where you want them. Easier to go slow and add more rather than overshoot your target and have to lower them. Hope this helps.
    Looks like you are doing fine. Your FC MAY be a little high if your CYA is 80, but I wouldn't worry about it--if it's actually 100, as you posted before, FC of 11.5 is perfect.
    T/A and pH were low--again, blame those Tri-Chlor pucks. Not only do they add CYA, they add acid and drop pH. This CAN be good (such as with a new concrete/gunite pool that's curing--the pucks add needed CYA and fight rising pH) but isn't always.
    Bleach and LC are, were, and will be the simplest and least side-effects way to add chlorine. (OK, SWGs are great, too, even easier). You need to stick with that or Cal-Hypo. But if you use Cal-Hypo, check your Calcium levels regularly. Or you could get an SWG.
    Jul 2006
    Hi and thanks for everyones help.
    its a pretty day in Jersey
    new numbers-
    FC - 13.5
    CC - 0
    pH - 7.2
    CYA - 100
    TA - 130
    Calcium - 100
    so we went up on ph from 7.0 to 7.2
    and up on TA from 50 to 130
    a little up on FC and Cal...
    ill go with another 1/2 box of 20 mule.
    thoughts?
    I think I would leave the pH alone for a day or two and see if it stabilizes there. 7.2 is a pretty good level.
    Yes, it is a pretty day in NJ. But the clouds keep covering the sun and it's a bit breezy. The kids and I were in and out and back in again...
    Jul 2006
    After a backwash and a few inches of fresh rain here are my new numbers.
    first set is the old -------- new.
    the only big difference i see is my CH, from 100 to 70?
    FC - 13.5 ----------- 13
    CC - 0 -------------- 0
    pH - 7.2 ------------ 7.4
    CYA - 100 ---------- 100
    TA - 130 ------------ 140
    Calcium H - 100 ---------- 70
    Thoughts?
  1. First time test results for pool
    By tbatti in forum DPD-FAS based testing
    Last Post: 07-13-2008, 09:29 AM
  2. Newbie with first-time test results
    By halefmly in forum DPD-FAS based testing
    Last Post: 07-28-2006, 10:16 PM
  3. First time PS234 Test Results
    By Mr Bill in forum DPD-FAS based testing
    Last Post: 07-10-2006, 03:28 PM
  4. 1st Time Test Results
    By vanduse1 in forum DPD-FAS based testing
    Last Post: 06-15-2006, 11:51 PM
  5. 1st Time test results
    By Bnelson in forum DPD-FAS based testing
    Last Post: 05-29-2006, 02:16 PM
