Results 1 to 10 of 15
Thread: Help w/ Numbers
    Default Re: Help w/ Numbers
    I tested my soft water this morning, pH was low but ALK was just the same as whats in the pool now. LOL Guess Ill just have to master the use of adding acid, and aerating!
    Minnesota
    My well water must be like yours. Even the soft water is highly alkaline, so I, too have to add acid. My pool this morning tested at 210, after closing around 100. But then, I just added tons of water back in. The "bigger problems" that I referenced were high iron and other metals and off the chart calcium hardness. The softener does help with that.
  1. Help me with My Numbers?
    By mkfmedic in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-07-2007, 02:28 AM
  2. Here's my numbers
    By nicoleh in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-31-2006, 12:32 PM
  3. My numbers...HELP
    By Dafreak in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-26-2006, 05:56 PM
  4. WOW my numbers are off
    By Bowlin in forum Dealing with Alkalinity and Calcium
    Last Post: 05-25-2006, 10:19 PM
  5. Here are my numbers...?
    By crazimom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-17-2006, 12:28 PM
