Results 1 to 10 of 15
Thread: Help w/ Numbers
    mas985's Avatar
    Pleasanton, CA
    Default Re: Help w/ Numbers
    Yes, a water softner will help but you may want to test your tap water first to see what you are dealing with.
    Mark
    Is there a formula for how much acid to add and how long to wait before adding more?
    Indiana.
    Quote Originally Posted by dustybecca
    Bleachcalc will do acid too. I usually wait 4 or 5 hours before retesting. Better to sneak up on the right reading than to blow past it at 70mph. I don't even retest everytime anymore. I know what a quart of acid will do, so I just add it and wait.
    OK Ive got the pool churning, (aerating w/ fountain, garden hose w/ high pressure nozzle in one return and the other return pointed to the sky) I've added about 4 cups of acid. Now Im waiting. Ill let you know how it turns out. Thank you SO much for all your help!!!!!
  1. Help me with My Numbers?
    By mkfmedic in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-07-2007, 02:28 AM
  2. Here's my numbers
    By nicoleh in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-31-2006, 12:32 PM
  3. My numbers...HELP
    By Dafreak in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-26-2006, 05:56 PM
  4. WOW my numbers are off
    By Bowlin in forum Dealing with Alkalinity and Calcium
    Last Post: 05-25-2006, 10:19 PM
  5. Here are my numbers...?
    By crazimom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-17-2006, 12:28 PM
