Did I read your numbers correct, total hardness is 740 ppm? This is pretty high. Recommended levels are 200-400 ppm. Do you have very hard fill water or is something else going on? With this high of hardness, you are well above the optimum saturation index which means that you may experience scaling and/or cloudy water.
