Results 1 to 10 of 11
Thread: calcium hardness/ metal control new to me, do I need them
    Default calcium hardness/ metal control new to me, do I need them
    Here is our reading from the pool store, we have a fiberglass pool.
    TC = 5
    FC = 5
    Ph = 7
    TA = 25
    Calcium hardness 185
    CYA 80
    total dissolved solids = 600
    This is the plan from the pool store-
    Add 16 oz of metal control to stop staining - wait 24 hours
    then add 7 lbs of total Alkalinity increaser (sodium hydrogen corbonate)
    wait 24 hours
    Then add Calcium Hardness Increaser 10 lbs one day and 10 pounds next day.
    We've had the pool for one year and last year the chemicals stayed good. So I have never added metal control or calcium. Since we have a fiberglass pool do we need to add calcium? So I'm not sure if this is right, can I get some advice please.
    Default Re: cacium hardness/ metal control new to me, do I need them
    Quote Originally Posted by karenib View Post
    TC = 5
    FC = 5
    Ph = 7
    TA = 25
    CYA 80
    Boy! Do I HATE pool stores! Nowhere did they give you a metal read-out. TDS=600? So What? TDS is one of those scare-tactic measures, like Phosphates.
    You have a very, very low TA, a fairly low pH, a surprisingly high (but manageble) CYA
    My suggestion? Raise your pH to 7.3 to 7.6--use Borax. Raise your T/A to 80-100--use Baking Soda. Or, use Washing Soda (in the Arm 'n' Hammer YELLOW Box) instead of both Borax and Baking soda.
    I think you need to shock your pool up to 20ppm--green may be metal, but with no metal read-out it's more likely algae. Your FC is the MINIMUM for a CYA of 80, but I think it's too low--the scale is vague--for CYA of 60-90, use an FC of 5-10 and shock to 20. You, at 80 are at the higher side, so FC of 8 or 9 should be your minimum.
    Pool stores always come up with expensive solutions to problems. Try the basics first.
    And, if our metal expert disagrees with me, she'll merely tell you to use a metal sequesting agent, but before you shock the pool.
    My pool store said I needed 6 lbs of calcium hardness today also. I was also wondering if I needed it? I have never put it in before. All other chemicals were fine. It is a little clouldy for some reason.
    Above ground vinyl 7500 gallon
    80 calcium hardness
    FAC 5
    PH 7.2
    TA 90
    CYA 40
    No I didn't buy it. Thanks for the input I had no idea and thought I would ask here first. Thanks
    mbar's Avatar
    Ashland, PA
    You do need some calcium in a fiberglass pool, but I wouldn't add that much. You can just keep what you have, I usually keep my calcium at around l50 - 200. I usually keep my ph between 7.2 and 7.4. Raise your alkalinity to about 80, the way CarlD says. Don't worry about tds. Carl is right with a cya of 80, you need a minimum of 5ppms chlorine, and a max of 10ppms and to shock you need 20ppms. So you may not want to use any chorine pucks (trichlor), because that will add cya. You can use calhypo - it will add calcium to your water with it. Bleach won't add anything but salt - which won't do anything to your pool. If you don't have any stains, you don't need any metal out. If you do see some staining, then you need to use something that sequesters metals. Feel free to ask any other questions you may have.
    Northeast PA
    My DH didn't want to wait,he wants to go swimming tomorrow and the guy said not to go in the water until the ph is higher. So he added 7lbs of alkalinity increaser only. I'll have to see if I can find a pool store to run a test tomorrow or monday to check my numbers again. We didn't add anything else.
    just a note, the water is crystal clear and there were no stains on the walls...so we didn't have any problems - we just had the water tested to check the TA and ph.
    mbar's Avatar
    Ashland, PA
    That's fine. You should have the alkalinity between 80 - 100. Just don't add the calcium. You do have to add more chlorine - get it up in to around 8ppms, this way when people start to swim you won't go below 5. After a couple of hours of adding the alkalinity up check your numbers.
    Northeast PA
    Thanks Marie. Do you think I should hold on to the bottle of metal control in case I do get staining. The rest of the chemicals are going back to the store
    Karen
    Karen - You said you were trying to raise ph so you added alkalinity increaser. Ph and alk are not the same thing. You raise ph by adding Borax. You raise alk by adding baking soda. If your alk was already 90, then I hope adding the 7 lbs. of alk increaser doesn't raise your alk too much.
  1. calcium hardness
    By walker1 in forum Dealing with Alkalinity and Calcium
    Last Post: 09-08-2012, 11:49 PM
  2. Calcium Hardness
    By Ciscokid in forum Dealing with Alkalinity and Calcium
    Last Post: 05-30-2007, 03:29 AM
  3. calcium hardness
    By boscogabby in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-09-2006, 04:25 PM
  4. Metal Control
    By Sprint54 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-21-2006, 09:27 AM
  5. Calcium Hardness
    By PaulE10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-15-2006, 11:52 AM
