Results 1 to 10 of 10
Thread: Is TA 140 too high?
    Default Re: Is TA 140 too high?
    Thanks for catching the typo. As far as lowering TA there is a sticky here on the forum that explains how.
    One thing I have to caution you. This is a pool, not a science experiment You are starting to overthink things and looking for problems before they materialize.(I have been following your threads, as you know). Now I can debate the theoretical chemistry with the best of them (as the long timers on this forum well know) but I choose not to unless their is a REAL reason to.
    My suggestion is to start ENJOYING your pool and stop worrying so much about water balance. That's wny we got 'em in the first place, right? You hvae been given advice. Don't overthink it.
    BTW, the amount of bubbles produced by your pooskimmer should not have any major impact on pH rise since the amount of aeration produced is going to be small. This is what I mean by overthinking.
    Brookline, MA USA
    Thanks for all the advices. I certainly plan to enjoy my pool, as I've used to, once the weather gets better here and the pool is ready.
    However, I’ve learned from my experience so far that if I don't follow the RIGHT balance and sanitation, there's more work and more trouble. Most likely this is why I got the pink algae last year, which was a pain to get rid of. Also, in the past my pH was never stable. Now I want a smoother operation. As for the aeration - I think I saw in this forum more than once that this changes the pH.
    My pH already drifted in one day from 7.5 to 7.6, so what was said here about the need to lower TA was probably right.
    All in all my plan is to start with a good balance first and than to enjoy the water with as little work as possible.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP
    38 SF DE filter, 1 HP Hayward Super Pump
    Raypak 350k BTU Natural Gas Heater and solar cover
    8 gal Liquidator with bleach
    Dolphin robotic cleaner
    Taylor k-2006 test kit
  1. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 04:47 PM
  2. High amounts of DPD Powder needed!! To high or no Clorine?
    By KaseyNewman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-16-2012, 10:52 PM
  3. High Phosphates > 1,000 & High Nitrates 90ppm
    By applepar in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2011, 04:49 PM
  4. had algae, PH high, TA high, water now cloudy
    By Mom4fun in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-12-2011, 12:09 PM
