Originally Posted by LostboyinVA
We use regular goals from Sports Authority. I have the adjustable kind so I adjust them to the lowest level. They are about 8 feet from the ground when you are in the pool.
As far as dribbiling goes, you are dribbiling, when you hold the ball with 1 hand out of the water. If you ever hold the ball with two hands, you stopped dribbiling and can not move. We call double dribble. This works pretty well because it is fairly easy to knock the ball out of someones hand when they are holding it with one hand.
