Thread: changing skimmer / manufactures
    Default changing skimmer / manufactures
    I need to replace my skimmer, the complete assembly.
    The one that came with the pool is a Waterway Plastics model and I can't find a replacment. My problem is; I would like to replace it with a solid name brand "Hayward" but none of the ones I have looked at have the same cut-out dimentions or number of mounting holes what do I do?
    Darrell W. -------------------------------------------------------------------
    Man!,this water is cold!
    9,240 Gallon
    15'X 26'above ground
    Using BBB method of chemistry
    Hayward X-Stream 100sq ft cartridge filter
    Hayward 1hp Matrix pump
    Daytona Beach,FL.
    Default Re: changing skimmer / manufactures
    Waterway is actually a very reputable brand for skimmers.. I wouldn't hesitate to buy another one...
    your other option is to buy a skimmer with a bigger opening and enlarge your opening/redrill the screw holes.
    A skimmer with the same size opening but different hole pattern "should" be ok, because the gaskets used will create a watertight seal, but if you're not comfortable with that idea, don't do it.
  1. Changing Sand
    By Cindy32tn in forum Dealing with Algae & Slime
    Last Post: 06-27-2012, 09:14 PM
  2. How to repair an IG liner leak at the skimmer interface and replace skimmer
    By ralph in forum In-Ground Pool Construction and Repair
    Last Post: 02-29-2012, 10:37 AM
  3. Changing over to BBB's
    By renlo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-01-2011, 05:17 PM
  4. Changing over to BBB and a little scared
    By Gracy101 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-18-2006, 06:11 PM
  5. Changing the weir gate in a Jacuzzi PMT skimmer
    By davegs in forum In-Ground Pool Construction and Repair
    Last Post: 06-11-2006, 11:46 PM
