Results 11 to 12 of 12
Thread: Confusing info from Taylor Technical support
    Default Re: Confusing info from Taylor Technical support
    Carl, I appreciate the help. As you well know, patience and persistence is powered by the knowledge that it's not all a futile effort. This forum rocks.
    for the record, what amount of FC depletion should be my goal overnight? i.e. What is my goal or stopping point, do you think I need to keep shopping 2x a day?
    Last night was down 8ppm.
  1. So confusing about chemistry!!!!
    By reboot530 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-06-2012, 01:18 PM
  2. Pool Water Chemistry (Warning: Can Get Technical)
    By chem geek in forum The China Shop
    Last Post: 06-02-2007, 03:28 PM
  3. Pump Efficiency, Head, Flow, and related technical info
    Last Post: 02-02-2007, 12:39 AM
  4. Confusing CYA readings
    By mshumack in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-26-2006, 04:04 PM
  5. Technical question for pros: about bleach
    By smokeygrl in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-11-2006, 02:27 PM
