I have been a pool owner for about a year now and I must admit that I didn't do a good job running the pool. I promised my self that I would learn the correct way.
My pool is really brown/cloudy. Here are my test results.
About 20000 gallon plaster IG pool
Hayward cartridge filter has been on 24/7 for weeks
CL - off the chart. I put 6 large bottles of bleach in yesterday (4-25-06)
PH - 7.2
Total Alkalinity - I stopped putting drops in the tester at 70 drops
Total Hardness - I added 5 drops of hardness indicator and the water started to turn blue until I mixed the water then it went clear.
CYA - About 120
I think the first thing I need to do is get the CYA down no?
Any help would be much appreciated.
Edit:
I read the FAQ on HOWTO: Step-by-Step Guide to lowering your alkalinity.
I turned on the water fall to help aerate the pool
Should I put acid in the pool even know my Ph is low? I will hold off on putting anything in the pool until I am instructed to.
