Results 1 to 10 of 22
Thread: Adding BBB
    Brookline, MA USA
    Default Re: Adding BBB
    My responses below in bold.
    Hope that helps.
    Richard
    Thank you again, Richard, for this detailed response.
    I understand that it's beyond the scope of this part of the forum, but I'd be interested to see the chemical details of the correlation between CYA level and the amount of FC needed to shock. You mentioned before a paper presented long time ago. Has anything been published so far on line?
    Also, it's not easy to understand why such a high level of FC is needed to break 0.5 - 1 ppm CC in an alagae-free shock treatment. In my case it's 19.8 FC (CYA =50), taken from the table you posted at troublefreepools.com. Is it because of the fact that in the presence of CYA, "free" HOCl doesn't exist, but it's rather bound to CYA?
    If we need to move on to the China Shop for this purpose, please let me know.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP
    38 SF DE filter, 1 HP Hayward Super Pump
    Raypak 350k BTU Natural Gas Heater and solar cover
    8 gal Liquidator with bleach
    Dolphin robotic cleaner
    Taylor k-2006 test kit
    Continuing in the China Shop in this thread.
  1. Adding CYA
    By utahpool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-28-2010, 01:26 PM
  2. low pressure when adding DE.
    By Amir in forum Pool Equipment & Operations
    Last Post: 05-24-2009, 05:10 PM
  3. adding cya
    By tara15 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2007, 08:05 PM
  4. adding cya to pools
    By cleland418 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2006, 02:16 PM
  5. Adding CYA
    By satj in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-14-2006, 10:07 PM
