Thread: Cover blew off some, green water on top now in the pool
    Carterville,IL
    Default Cover blew off some, green water on top now in the pool
    ok, so thank god we missed the tornadoes, but the wind took part of my cover off and in went some of that nasty green water into my "WAS" crystal clear pool. Opening in about 2 weeks hopefully....this years weather is crazy. Any suggestions for preventing more work later???
    30' Esther Williams Classic Granite
    Installed july 2006
    Default Re: Cover blew off some, green water on top now in the pool
    If you have a sump pump, or anything else to provide some circulation for a couple of hours, you can add a gallon or 2 of bleach and replace the cover until you're ready to open. Hopefully this will keep the algae that got in the pool 'at bay' - or outright kill it Any large debris that you can easily get out will also help prevent a swamp when you open.
    Sorry the cover went in, but at least the entire pool isn't in the next county
    This has happened to me several times before and it doesn't take that long to clear it right up. No big deal other than it is disappointing to see your clear water get yucky.
    Carterville,IL
    Thanks guys...all was perfect. Just a little OOKIE, but no problemo like you said watermom.
    Opened it a few weeks after the incident, had added one bottle of algaecide 60 a day or two "after" the incident and had the best "no algae" season of the year....although it was a cool summer.
    Installed july 2006
  1. Hayward DE Filter Blew top of Air Release valve off??????
    By bell7272 in forum Pool Equipment & Operations
    Last Post: 06-04-2013, 07:34 AM
  2. Just pulled cover off.. green swamp water
    By slade8200 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-18-2011, 05:59 PM
  3. Storm blew smoker into pool
    By shawnandjenn in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-26-2011, 06:50 AM
  4. cover off - green water - pump broken
    By masspool in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-09-2010, 02:58 AM
  5. Cloudy green pool can I use the solar cover
    By nicole12 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-26-2010, 11:17 PM
