Results 1 to 10 of 15
Thread: Help me solve this problem please
    Default Re: Help me solve this problem please
    Not just the northeast! We have major pollen with all the flowering trees in WV! If you can get away with cleaning out your skimmer sock only 2 or 3 times a day, I'd say you are lucky. Mine gets clogged every couple of hours!
    Sherwood, Arkansas, USA.
    I'm going to run by the pool store on my way home today and see what they have so I can test cya. The only cya that gets in my pool is from the pucks in the chlorinator. I'll see if they have a skimmer sock as well - or I'll just pick up some pantyhose.
    I tested last night and the ph is up to 7.6 so I guess that's about where I want that. I shocked the pool some more just for the heck of it. And I turned off the chlorinator just in case my cya is getting out of hand.
    I'll keep you guys posted. Thanks for the info.
  1. Please help...never had this problem before
    By Mattcef in forum Dealing with Algae & Slime
    Last Post: 06-19-2012, 07:36 PM
  2. Having a problem we never had before.
    By Hadestech in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-26-2011, 07:24 PM
  3. Algae problem or fliter problem ?
    By ROBIN13 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-14-2006, 02:29 PM
  4. PH and TA problem
    By aguaguy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-27-2006, 02:46 PM
  5. Big problem! Need help!
    By kelleyb in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2006, 06:08 AM
