Results 1 to 3 of 3
Thread: Foam Bottom
    Default Foam Bottom
    Well our pool will be delivered next Thursday. Ground is pretty much ready. I was unsure of what to use but am now considering a foam bottom. I like the idea that it protects the liner better then sand. Don't have to worry so much about rocks working them selves up. Plus I hear the foam bottom is nicer and easier.
    For those that have used foam what is the best type to use and how thick? Also do you tape both sides top and bottom or just the bottom?
    Also I guess when you use foam you have no choice but to use a manufactured cove. What is the best name brand for that ?
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    Default Re: Foam Bottom
    We looked at the foam bottom but decided to go with the Gladen Perfect Bottom as it protects the liner from nutgrass, insects, and is perfectly smooth with no footprints or wrinkles. It feels similiar to an inground pool with a concreate pad underneath.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
    Cordova, Tennessee
    Where are the pics?? I can't find them.
  1. Can't get bottom flat, can pool bottom be slightly concave/bowl shaped?
    By SkierDude in forum Intex-type Pool Setup & Operations
    Last Post: 06-30-2013, 12:13 PM
  2. Foam Bottom
    By Ltvanloon in forum Above-Ground Pool Construction & Repair
    Last Post: 06-24-2008, 09:51 AM
  3. Foam bottom and Cove
    By CliffTex in forum Above-Ground Pool Construction & Repair
    Last Post: 09-11-2006, 02:04 PM
  4. Do you HAVE to use a bottom and foam?
    By denanbob in forum Above-Ground Pool Construction & Repair
    Last Post: 06-11-2006, 11:33 AM
  5. Foam bottom with sand cove
    By scottfly in forum Above-Ground Pool Construction & Repair
    Last Post: 05-13-2006, 10:04 PM
