Thread: 3rd year with pool, 1st time testing it right.. Please advise
    Default 3rd year with pool, 1st time testing it right.. Please advise
    Hey guys. After a couple solid years of frustration I found the forum, read the faqs, studied the archives, and am beginning to get a grasp for the water.
    I pulled the cover off and my K2006 fas-dpd test kit arrived.
    25k gallon vinyl liner
    Crystal clear water
    Here are my results.
    FC: .6 ppm
    CC: 1.6 ppm
    PH: 7.5
    TA: 80 ppm
    CH: 130 ppm
    CYA: All I can say is it is less than 30 ppm using the black dot test because I filled the tube all the way up and could still barely see the black dot.
    Thanks for the help, I just didn't want to "wing it" in the beginning steps of making my pool perfect.
    Default Re: 3rd year with pool, 1st time testing it right.. Please advise
    shock the pool and bring your CYA up to about 40 ppm. Then maintian your FC at about 4 ppm and you should be good to go. You might find that you have a chlorine demand at first (as indicated by perisistant CC and FC not holding) so just keep shocking to 15 ppm and holding it there until the CC is gone and the FC is holding. The rest of your numbers are perfect.
    thank you very much for the advice, I followed through this evening.
    Evan just makes my job easy!
  1. Testing water for first time this year
    By Digger in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-20-2012, 02:42 PM
  2. Its that time of the year again.
    By sparklewater in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-04-2011, 06:28 PM
  3. Testing Time
    By mohawk in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-09-2006, 11:23 AM
  4. Terrible time checking PH this year
    By mswlogo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-24-2006, 08:12 PM
