Thread: Fixing Wrinkles
    jrv331 is offline Registered+ Thread Analyst jrv331 0
    Default Fixing Wrinkles
    I'm going to try to fix a few liner wrinkles towards the top of my water line and just want to make sure I"m doing it right. I have a 24ft A/G with a vinyl liner that overhangs the top(not the beaded type).
    I'm going to drain about 1/4 of the water, then take off the top rails and plastic trim that holds the liner in place around the entire pool. I'm just going to pull the liner up a section at a time until the wrinkles are gone, for tougher wrinkles I'm going to use a hose and flow water behind the liner until the wrinkles smooth out. As I remove the wrinkles I'll replace the trim and top rail to the keep it wrinkle free.
    Any problems doing it this way? I know I should be using a vacum somewhere in the process but I"m not sure how and am afraid I'll cause more damage.
    Thanks for any advice
    John
    Thumbs up Re: Fixing Wrinkles
    John, sounds like you're going about this the right way I'm assuming that the wrinkles are horizontal, not ~ vertical - if they were ~ vertical, you'd have to slide the top of the liner around to get them out. There is no need for a vac with the overlap liners, and in fact I wouldn't use a vac for any liner if you're only lowering 1/4 of the water - as long as you have 6+" of water up the wall, the vacs aren't necessary.
    Good luck with getting the liner wrinkle free
    --Ted--
    Default Re: Fixing Wrinkles
    Ted,
    Most are horizontal but I do have a few vertical. What do you mean by "slide the top around"? Im figuring I'll have to pull the liner away from the wall anyway and move it around a little.
    John
    Smile Re: Fixing Wrinkles
    Again, you've got it right! The top of the liner would have to be moved in the direction of the bottom of a ~vertical wrinkle to make it go away - you can't get 'too crazy' with it or you'll cause a wrinkle in the other ~ vertical direction
    I hope this is enough, if not - just ask
    Just a follow up question, my overlap liner has the black plastic strips that fit over the top of the liner. Should I wait to fix all the wrinkles to put them back or can I put them on as I work out the wrinkles one section at a time.
    John
    I would take it 1 or 2 sections at a time unless you had to have more of it off to work the entire wrinkle.
  1. fixing pool leak?
    By vinouspleasure in forum In-Ground Pool Construction and Repair
    Last Post: 07-27-2011, 08:38 AM
  2. Fixing alkalinity with the BBB method in Texas
    By RossM in forum Dealing with Alkalinity and Calcium
    Last Post: 06-06-2011, 10:13 PM
  3. Fixing an old Anthony vs. buying a new Hayward
    By Water_man in forum Pool Equipment & Operations
    Last Post: 05-22-2008, 10:25 PM
  4. Fixing my swamp
    By jtnaylor in forum Dealing with Algae & Slime
    Last Post: 03-17-2008, 04:42 PM
