Results 1 to 10 of 11
Thread: Solar Sun Rings
    CT
    Default Solar Sun Rings
    I purchased 7 of these for my pool to try this season instead of the solar blanket. I got a good price on them. Anybody try them. I checked their site and they sound good.
    Here is their site:
    http://www.solarsunrings.com
    Default Re: Solar Sun Rings
    I think there were a few threads about them last year and the general concensus was that they don't live up to their hype...
    CT
    I think that is the reason for the $12.99 price. I wanted to give them a try as I like the concept that they do let some of the pool to be exposed to let the chemicals gas out. The negative would be the temperature loss at night.
    I just bought 12 for my 24' round. We've had a crappy May so far so it's hard to say how well they work. However they are not as easy to put on and remove as I thought. I thought the ring was made out of fiberglass but you just blow them up. They tend to flop over in a good wind. Once you get them out of the pool they're a little tough to handle.
    BUT....it is a lot easier than the full solar blanket. Once we get a break in the weather I'll report back how they work out during the swim season.
    CT
    UPDATE:
    Day one - Installation no issues, the trick was not to overinflate the outside ring or it would not lay flat. Seven?? I think they are two short. There is a lot of uncovered surface. Two more would be tight, but it would cover more of the surface. Otherwise, the heat gain (if any) would be lost at nighttime. I have left over trimmings from solar blankets, so i formed a Hybrid solar cover: 80% Solar Rings / 20% Solar Cover
    1 hour after inflating all seven - Two have lost air on the outside rings. The valve stem "covers" popped out. They are too loose fitting. Sent an email to the company per instructions enclosed within package.
    I will let know the outcome, favorable / unfavorable. I will be unbiased and if the company does not honor the warranty, all of you will know.
    CT
    I received my replacement rings today from the company.
  1. Solar Sun Rings
    By bswift in forum --cleanup--
    Last Post: 10-01-2012, 10:39 PM
  2. Solar Rings
    By kelemvor in forum Pool Equipment & Operations
    Last Post: 05-26-2011, 11:12 AM
  3. Air Leak? (from bad O-rings in Jandy valves)
    By cajunfla in forum Pool Equipment & Operations
    Last Post: 04-15-2008, 09:15 PM
  4. Solar Rings??????
    By badkins in forum Pool Equipment & Operations
    Last Post: 06-09-2006, 01:34 PM
  5. Opening pool-found 2 unknown o-rings
    By wetshoes1 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-31-2006, 06:04 PM
