Thread: Cloudy Teal Blue Water
    Jul 2006
    Default Cloudy Teal Blue Water
    Pulled the cover off my pool about a week ago to find a green mess. I dumped bleach in to kill the algae. For the first week I kept the chlorine level at around 20 ppm. The pool cleaned up some but is still a cloudy, light teal blue. I can see about half way down the sides on the deep end which is ~8 feet.
    Here are my current numbers:
    pH: 7.6
    TA: 80
    Calcium Hardness: 230
    CYA: 40
    TDS: 800
    Since I found my CYA level to by ~40, I have been keeping my chorine levels around 15 to try to clear it up. I am thinking maybe the problem isn't algae. How can I clear up the water and getting in swimming condition... Hopefully by May 16, when my daughter wants to have swimming party (brrrrrrr) for her birthday.
    BTW, If I lower the pH with muriatic acid, "about how much" do I add to lower the pH "about how much"?
    Thanks,
    Ed
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
    Default Re: Cloudy Teal Blue Water
    I'd try lowering pH to 7.0 and see if it clears then. If not, it's something else.
    mbar's Avatar
    Ashland, PA
    Are you brushing the sides of the pool? What kind of pool do you have? If there is still some staining on the pool surface, it could make the water appear to be teal. Make sure you keep the chlorine up at 15 - 20 continuously, keeping the filter going 24/7.
    Northeast PA
    Jul 2006
    Yes... been running the filter 24/7 since I took the cover off.
    Are you running your pump 24/7 while you are trying to clear it? BTW, your ph is perfect at 7.6.
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
  1. cloudy blue water
    By nexxceleb in forum General Interest
    Last Post: 07-25-2013, 07:36 PM
  2. Blue cloudy water
    By Bama1992 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-01-2012, 10:43 PM
  3. cloudy blue water
    By berlin in forum Dealing with Algae & Slime
    Last Post: 07-20-2010, 03:54 PM
  4. Blue Cloudy Water
    By crystolsbrown in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-03-2006, 03:30 PM
