Results 1 to 10 of 10
Thread: Blue Diamond, Just got one!!
    Sardian is offline ** No working email address ** Sardian 0
    Default Re: Blue Diamond, Just got one!!
    Our Polaris is a year old also (was that is) and in the beginning it would work good one day and bad the next. Toward the end of last season it started never going to the shallow end. After trying over and over to "fix" it I gave up and ordered the Blue Diamond. So far I have had it about 1.5 weeks and it's been night and day. In about an hour my pool is clean....and I mean clean.
    It doesn't kick the stuff around, like dirt and such, it actually sucks it up into its bag.
    I'll never miss the sound of the booster pump running for all those endless hours either.
    I'm about to order a pool buster to go with it for those times when just a few spots need cleaning.....as soon as I can find a decent deal on one. I'm thinking of getting the CG model.
    Russell
    Quote Originally Posted by ivyleager View Post
    It sounds so easy and nice! Haven't received my PoolBuster back from WaterTek. Purchased a Polaris 380 last year when PB went bust. Polaris worked like a charm last year. I was pleased with it's ability to get everything off the pool bottom. This year is another story........seems to circle alot, doesn't get the shallow end much at all. Don't know if it's the cold water, or what. All I know is that I am tired of fighting any and all pool cleaners. Jeez, what does a gal have to do to keep her pool decent these days! A friend of a friend has a Aquabot T2 and loves it...they have a 20x40 IG vinyl. They have been thru the gambit of pool cleaners, too. While I really don't want to buy another pool cleaner again this season, I may have to bite the bullet and get a robotic. Most seem to be in the same ball park cost wise, so it's a matter of finally getting fed up with it all. I'm not there quite yet.
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Quote Originally Posted by Sardian View Post
    Russell
    Russell,
    Save the pool buster box.....you may to return it for service work. There's been a few tale on here about problems within the first year or so.
    When the PoolBuster works, you'll think it's the best thing since sliced bread. But the batteries can fail very quickly and the battery/motor must be replaced as a unit. I had to do it after the warranty ran out and it cost about $80, on a $200 unit. But since then it's been better than ever.
    Also be sure to order the finer-mesh filter--I don't know why the unit wasn't sold with that in the first place--it makes it an all-purpose vacuum. I haven't had my suction side vacuum out of the basement in 3 years between that and my Blue Diamond.
    Round Rock, Texas, USA.
    Hi All,
    I just purchased the "Pool Blaster MAX CG", and for my application (16K Gal IG Gunite pool with a tree leave problem) the Blaster is a toy that just wastes my time as I rearrange the debris and leaves on the pool bottom.
    The advertising for this product says it flows "up to 61 GPM". This is misleading since the actual flow is much much less than that. It does seem to pick up small pebbles and dirt Ok after multiple vacuum sweeps, but for leaves, just forget it.
    My reccomendation is to keep your money and use traditional vacuum sweeper and leaf eating roducts that are very inexpensive and effective. For illustration purposes two examples are shown here:
    http://www.poolsolutions.com/cart/clean.php
    I'd purchase elsewhere however.
    So if "Water Tech" has miss-represented the capabilities of the "Pool Blaster MAX CG" then why should I believe that the "Blue Diamond" is a good product?
    See my other posts on the "Pool Blaster MAX CG".
    Jim
    roady is offline ** No working email address ** roady 0
    md
    Where is a good place to buy the Blue Diamond?
  1. Need help with Decision on Blue Diamond
    By jkoch in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-05-2011, 10:11 PM
  2. Help with decision between Blue Pearl & Blue Diamond
    By ryguy in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-26-2008, 01:33 PM
  3. Blue Diamond Experience
    By Skillset in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-29-2006, 12:18 PM
  4. Blue Diamond versus Aquabot T2
    Last Post: 08-07-2006, 11:44 PM
  5. Anyone with a Blue Diamond or Blue Pearl cleaner?
    By luvapool in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-03-2006, 12:49 PM
