Auto and service are settings on the pool controller - auto allows the computer to control everything and service let's you control from the panel at the pump and filter.
Opening the pressure valve on the filter is how I originally got it to prime the first time.
Is it possible that there is a blockage on the suction side? It's a 2" supply so I can't imagine it's blocked. Also, I can't get it to prime on pool or spa setting, and I can't believe both lines could be blocked. Spa setting has both suction and return set to for the spa.
I disassembled the pump - thinking that I re-assembled it incorrectly.
I also have a spigot after the pump and before the filter. I've even opened it with no luck. So that would indicate it's not on the pressure/return side.
Thanks for the thoughts.
Kevin
