Results 1 to 10 of 16
Thread: Ph or Alkalinity...which should i fix first
    Default Ph or Alkalinity...which should i fix first
    We've just started working on our water quality last Saturday and we shocked the you know what out of it for a week. The FC is off the chart, but the pool went from a murky green pond to a deep, cloudy blue. I've got an Aquarite salt generator and i had to add close to 400 lbs of salt to bring it up to 3400.
    So, Alk and Ph are way off...both are very low. According to the calculator, with my pool holding 36500 gallons, I need to add 29.2 oz of Sodium Carbonate(soda ash?)..edit...read a bit more and can this be Borax instead? to bring the Ph up .2. So if i'm at 6.8 and i want to get to 7.4, i'll need to add approx. 87oz of this to get it up that level.
    My Alk is 0 and it looks like i need to get up to 80ppm. According to the calc, i need to add almost 40lbs of Sodium Bicarbonate(baking soda?) to get this up to 80ppm.
    So, does this sound right and which is most important to fix first. Also, it seems like i remember reading that alkilinity can be kept lower with SWGs.
    Any suggestions on this would be great.
    Thanks,
    Kash
    Indiana.
    Default Re: Ph or Alkalinity...which should i fix first
    Don't trust your pH reading while your pool is at shock level. I wouldn't adjust anything until the chlorine is back down to a more normal level.
    I second what John T said.....and when the chlorine is back down to norm and you test again, I would fix the pH first. The higher your alk is, the more stuff you'll have to add to get the pH to move.
    John and Janet,
    Thanks for the advice on this. I'll wait until the Chlorine is down to a workable level prior to doing anything else.
    Does a high chlorine level create cloudiness in the water too? I've turned by SWG down to 40% now and the water coming out of the returns is white'r(yeah, made that up...:-) than the water in the pool. You can actually see clouds of it coming out of the returns and moving into the pool. I doubt this is salt, but there still could be some of the bottom being pulled into the main drain. I can't tell as i can't see the bottom...:-)
    Kash
    I have to disagree. While high chlorine DOES affect pH, it usually makes it look high, not low. I would add borax (not soda ash) until pH passes 6.9. If it's above there, you can then wait for lower chlorine levels to get a truer reading, which may STILL be below 6.9--the danger point for vinyl pools.
    True, unless they are using strips or cheaper OTO test to test the water, AND the chlorine is exceptionally high...I have seen it happen in my own pool where the chlorine can get high enough to bleach out even the OTO test.
  1. Alkalinity stuck at 0...after 50 lbs. Alkalinity Increaser
    By heyaim in forum Dealing with Alkalinity and Calcium
    Last Post: 07-22-2012, 06:51 PM
  2. Alkalinity?
    By Tammy J in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2011, 03:56 PM
  3. Alkalinity Low??
    By Brunomax in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2007, 02:23 PM
  4. Total Alkalinity and Adjusted Total Alkalinity
    By cheshamjim in forum Dealing with Alkalinity and Calcium
    Last Post: 06-18-2006, 08:36 PM
  5. Alkalinity FAQ
    By VickieC24 in forum Dealing with Alkalinity and Calcium
    Last Post: 04-04-2006, 10:03 PM
