Thread: Cleaning hayward pump
    Michaela521 is offline ** No working email address ** Michaela521 0
    Default Cleaning hayward pump
    Is there anyway that you can clean a pump from scale and rust safely and effectively. Muriatic acid could be used to clean the pump but that would destroy all metal parts in it. There has to be some way. Thanks
    Default Re: Cleaning hayward pump
    bump.......
    Smile Re: Cleaning hayward pump
    Since Janet decided this needed a little 'bump' and no one else is answering, I'll give my advice.
    If all the seals are are good, no pool water should ever reach the metal parts - so whatever treatment you use won't effect them!
    However, we live in an ~'imperfect' world, so if you have a union in front of the pump -- you can remove the motor and disconnect the housing from the influent line and soak (using muriatic and ascorbic acids for the different problems) the whole housing to rid yourself of the unwanted scale or stains.
    If you take the motor off, you may need to replace the 'pump housing gasket'.
    Thanks. I was starting to think that I was the only one with these problems.
    I guess muriatic acid can be used then. I always assumed that the impeller was metal with some other parts. Searching the net I found a product called scaletec that sounds like it might work better than most methods but it could be just another one of those overly praised products. Thanks.
  1. Cleaning pump basket
    By Jacob99 in forum Pool Equipment & Operations
    Last Post: 05-15-2012, 01:09 AM
  2. Cleaning a Hayward DE Filter System
    By ryano in forum Pool Equipment & Operations
    Last Post: 06-25-2011, 01:06 AM
  3. Cleaning out pump impeller
    By day1 in forum Pool Equipment & Operations
    Last Post: 06-03-2007, 12:42 AM
  4. Cleaning my Hayward DE Filter - 1st time - Any tips?
    By wetshoes1 in forum Pool Equipment & Operations
    Last Post: 04-18-2007, 11:11 PM
  5. Hayward Jet-action Cleaning Wand
    By ChuckD in forum Pool Equipment & Operations
    Last Post: 06-03-2006, 03:33 PM
