Results 11 to 14 of 14
Thread: automatic pool cleaner
    KPROMERO is offline Registered+ Thread Analyst KPROMERO 0
    Broussard, Louisiana
    Default Re: automatic pool cleaner
    Thanks SPILL
    fog80 is offline Registered+ Thread Analyst fog80 0
    Columbia, Maryland, USA.
    Quote Originally Posted by fofa View Post
    I had a Hayward navigator, it worked pretty good for 5 years, then dead, and it cost too much to fix. So I bought a "The Poolcleaner", and so far it has been a wonder to behold. I think the Navigator covered the pool a tad better (but not by much), but this does leaves and acorns and small twigs that clogged the navigator. I leave it in 24 X 7 (maybe haul it out if we are swimming) and it stays in all winter also because I don't close my pool. Only been a year, but nothing has needed replacing, Navigator needed wings replaced once a year minimum, and nothing is looking like it is even close to wearing out. About the only wear parts would be the tire treads and "flaps" that ride on the pool surface. They have both suction side (what I have) and pressure side (no booster pump pressure type) cleaners. Might be worth a look at.
    www.thepoolcleaner.com
    Before I bought mine I asked around, and everyone that I ran across that had this one says it was great. So I tried it, besides it was cheaper than the hayward and much cheaper than pressure side cleaners and way, way cheaper than robotics which you have to remove each time.
    Good luck with your search and what ever you get, I hope it works good for you.
    how much did it cost?
    ThePoolClearner I got online (4 wheel model) for $200.00 (give or take some change). It was a close out sale, and i see they do not carry them now.
    Where did you get it?
  1. Polaris 9300 automatic pool cleaner
    By kmichelini in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-08-2010, 08:59 PM
  2. Please advise on my automatic pool cleaner
    By janmo in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2009, 12:52 PM
  3. Automatic pool cleaner by Frontgate....
    By cruzmisl in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-27-2007, 11:51 PM
  4. Plumbing Fitting for automatic pool cleaner
    By gdubs in forum In-Ground Pool Construction and Repair
    Last Post: 03-10-2007, 04:53 PM
  5. What automatic cleaner for AG pool?
    By AnnaK in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-07-2006, 07:19 PM
