Today i went out to backwash, pushed down on the handle to turn it, which it did about 1/4 turn, and then stopped. turned it back to run position and turned the pump on and a small amount of water started leaking from the top. Pump off, tried to turn to backwash, 1/4 and stuck and not it will not budge.
So, i unscrewed all the nuts and pulled the top off( it was hard to do , but finally came out easily.)
I expected to find something jammed up, but didn't, handle still will not turn, and i am unsure of what to do next.
Any ideas?
Should i replace/lube anything while this is apart?
Going to take this piece to the pool store tomorrow, but thought someone here might have some insight.
Thanks much
