Thread: Water draining from my Filter when pump is off
    Texas
    Default Water draining from my Filter when pump is off
    I have a Jandy DE filter with a pretty basic backwash valve (push / pull type)
    I noticed last Fall that when the pump shuts off (after a cycle) that I can hear lots and lots of water leaving the filter and running into the pool. I have a sight-glass in the return line that I can see the water running through.
    When the pump comes on there is a lot of air in the filter that needs to be bled off.
    About this same time I started to notice water running out the backwash line when the pump is running.
    I'm concluding the two are related, since I don't see any leaks anywhere else, there must be a leak in the backwash valve letting air into the system and partially draining the filter when the pump shuts off.
    I've removed the valve, cleaned and lubricated the o-rings, but the problem persists. In fact it's getting worse. When the pump is running there is a lot of water running out the backwash line.
    The o-rings look good, but I think that is my next thing to try and replace.
    Does this sound like a reasonable thing to do, or am I way off base here?
    - Mike
    13,500 gal, gunite, white plaster, Aquarite SWG, 2 ft Waterfall and Ledge Bubbler
    Honesdale PA
    Default Re: Water draining from my Filter when pump is off
    I think you have a good handle on the problem and agree with your diagnosis and solution. Not familiar with those valves but don't think there can be another source of the leak. All the symptoms point to that. Multi-ports do the same thing when the gasket goes bad. That problem I have had.
    Good Luck.
    Texas
    Thanks! This weekend it should be warm enough to go out and try to replace them.
    - Mike
  1. Draining Filter
    By txtd1 in forum Pool Equipment & Operations
    Last Post: 04-23-2012, 08:23 PM
  2. Water draining from Spa when filter pump turned on...
    By Strawfoot in forum Pool Equipment & Operations
    Last Post: 07-20-2008, 03:28 PM
  3. water draining from filter
    By poolbee in forum Pool Equipment & Operations
    Last Post: 05-23-2007, 01:19 PM
  4. Draining with a cartridge filter
    By csevel in forum Pool Equipment & Operations
    Last Post: 07-23-2006, 12:29 AM
  5. Cleaning pump filter w/o water draining out.
    By les_smith in forum Above-Ground Pool Construction & Repair
    Last Post: 06-22-2006, 09:51 PM
