Thread: Leak around Backwash valve
    Default Leak around Backwash valve
    I have a Swimquipt backwash valve and it has been leaking from the top of the valve at the stem only when the pump is running. I opened up the valve and replaced and lubricated the o-rings, but it still leaks. Any ideas on what else I can do?
    Default Re: Leak around Backwash valve
    Barry, you've done what would fix the problem most of the time. The only thing I can think of, other than the o-rings failing, is that there is a hairline crack You might want to remove the handle and look at the top around the shaft under good light. Sorry I can't be more insightful.
    Thanks for the reply.
    I just took it apart again and installed some slightly larger o-rings. No change in the leak issue. I don't see any cracks anywhere. It seems to be leaking right around the shaft where it comes up through the top. I would think that would mean something is not sealed properly, but I don't know what else to check.
    Any other suggestions are welcome.
  1. Backwash valve issue
    By paintballergb in forum In-Ground Pool Construction and Repair
    Last Post: 06-18-2013, 07:59 AM
  2. Pentair Backwash Valve
    By RStalls in forum In-Ground Pool Construction and Repair
    Last Post: 01-11-2012, 07:35 PM
  3. Hayward Backwash/Control Valve Causing Leak
    By penn2131 in forum Pool Equipment & Operations
    Last Post: 06-11-2006, 12:45 PM
  4. Backwash Valve help
    By p.p.h. in forum Pool Equipment & Operations
    Last Post: 05-19-2006, 08:14 PM
