Thread: plaster life
    Default plaster life
    Anyone know the aproximate life for a standard plaster finish on an in-ground pool?
    Mine is about eight years old and its developing some hairline cracks. Nothing is loose, but the cracks are about six to eight feet and extend from the steps across and up to the grouted tile waterline in the shallow end of the pool. I have no idea how to mitigate this. The rest of the plaster is fine.
    The pool is overspec as far as the gunite shell and steel, so I'm sure there are no structural issues.
    Thanks!
    mas985's Avatar
    mas985 is offline Lifetime Member Whizbang Spinner mas985 3 stars mas985 3 stars mas985 3 stars
    Pleasanton, CA
    Default Re: plaster life
    It really depends on so many things that it is hard to say but the range I have heard is 3-20 years. Large, yes, because of the conditions of water, how well the water is kept in balance and how well it was installed. Harline cracks are usually not an issue.
    Mark
  1. Expected life of plaster
    By miker1755 in forum In-Ground Pool Construction and Repair
    Last Post: 08-07-2012, 01:28 PM
  2. Useful life of test kit
    By billp in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-16-2012, 04:39 PM
  3. Plaster repair: white blobs in minor cracks. Time to re-plaster or paint?
    By wpicot in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2012, 08:24 PM
  4. Is this the life, or What!
    By CarlD in forum General Interest
    Last Post: 07-19-2006, 03:23 AM
  5. Shelf Life of CYA
    By psteward in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-08-2006, 10:05 PM
