Thread: Need the Filter experts help asap?
    mjs31 is offline Registered+ Thread Analyst mjs31 0
    Texas
    Default Need the Filter experts help asap?
    My crappy Sand filter blew out on me the other day (probably the issue with my pump sputtering. Either way, I am going to go with DE filter this time around and want to keep my Pentair 2 speed pump. I am looking at the Pentair FNS Plus DE. Will I have an issue with connections if my pump has 1 1/2 inlet and outlet ports and the filter has 2" ports?
    Any quick help is appreciated since I still need to get some winterizing done and need a filter.
    Thanks for your help
    Mike
    Cool Re: Need the Filter experts help asap?
    Mike, no trouble with the different sized pipes, all you need is a bushing (reducer0 to convert from 1.5" to 2". There are also specialty male adapters that have 1.5" threads and a 2" socket. It's pretty easy stuff but if you need more info, you know where to ask.
    BTW - make sure the filter is large enough to handle the pump on high speed
  1. Questions for pool experts (or quasi experts)...
    By bigdog360 in forum In-Ground Pool Construction and Repair
    Last Post: 02-21-2012, 12:04 PM
  2. Wow...this is a job for the experts
    By bluecamel in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 10-30-2006, 09:47 AM
  3. Experts, I Need Help w/ First Pool Purchase
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 08-01-2006, 12:34 PM
  4. Polaris 65 experts needed
    By jenpen400 in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-30-2006, 07:20 PM
  5. Need Some Help From the Experts
    By jrv331 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-07-2006, 01:51 PM
