Thread: Pump sputtering bad on start up (high speed)
    mjs31 is offline Registered+ Thread Analyst mjs31 0
    Texas
    Default Re: Pump sputtering bad on start up (high speed)
    Quote Originally Posted by Poconos View Post
    Can't really think of anything to help but can you tell if there is any air getting into the pump basket? Also, can you tell if the motor is up to speed when the shaking occurs? The shaking is strange.
    It is probably an air issue. If I start in low speed and then click to high speed it purrs...but most times when I start it in high speed it will sound like it is struggling badly. I do notice that several time when I then restarted it I get a huge amount of tiny bubbles out of the return line. Probably air. I guess starting in slow speed is a subtle way of priming it?
    I have a one-speed pump that when the pump was cold and I started it up, it would struggle to get going. Once it was running it kind of surged all of the time instead of running smooth. If I shut it off and then right back on it worked fine.
    Mine ended up being a bad startup capacitor on the motor. Maybe the capacitor is bad allowing enough juice to start in low speed but not enough for high speed.
    Check this post and it will tell you how to check the capacitor. http://www.poolforum.com/pf2/showthr...t=hayward+pump
    Texas
    Thanks...you may be on to something. I tried again today and the same thing happened. I didn't have a 2x4 but my boot worked. I gave it a decent boot and it started up. Will have to clean the contacts when the weather clears. Thanks much for the post.
    Quote Originally Posted by brittmer View Post
  1. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  2. I have a 2 speed pump - when to use low? When to use high?
    By Jacob99 in forum Pool Equipment & Operations
    Last Post: 05-03-2012, 09:52 PM
  3. Sand filter changed @ start of season ? HIGH PRESSURE @24 PSI FROM START
    By timmygreene in forum Pool Equipment & Operations
    Last Post: 05-21-2010, 07:48 AM
  4. 2 speed pump. High speed puts sand in pool?
    By mjs31 in forum Pool Equipment & Operations
    Last Post: 08-23-2007, 06:00 PM
