Closed Thread
Results 1 to 10 of 11
Thread: Safety Rope
    Dec 2005
    Denham Springs, Louisiana, USA.
    Question Safety Rope
    I just had a 18 x 36 inground vinyl liner pool installed. My pool builder forgot to install the safety rope holders. When I asked about it. He said that the holders are installed in the concrete decking, not in the pool walls and that it is usally a tripping hazard, so most people don't install them. My question is are they really supposed to be installed in the decking or on the pool walls?
    Indiana.
    Default Re: Safety Rope
    They usually go through the coping. Your pool builder would be strung up and quartered in court if he was ever sued. The guys that put mine in were very firm that the safety rope and diving signs be in place when they left.
    rferrel1 Guest
    I am a newbie lurker here but - last week I had the opportunity to attend a video conference on recreational water safety. Although the seminar was targeted at public water safety issues, the vast majority of drownings nationwide occur in private pools/water and one of the big things they mentioned was not having the safety rope up so that people knew where a drop off was - even experienced swimmers can become disoriented when they are caught off guard by a sudden change in depth.
    Dec 2005
    The pool is finished. He has to come back to install my safety net. If I have him install the pool rope correctly, will I be at a greater risk for a leak since he would be installing it after the fact?
    My safety rope anchors are in the wall of the pool slightly below the tile.
    I forgot to mention my pool is concrete. If I had vinyl I would not want them below the water line, just one more place for a leak.
    Indiana.
    Quote Originally Posted by crosso
    In my vinyl pool, they are mounted well above the water line at the top of the coping, but they are anchored in the deck concrete.
    Dec 2005
    Thank you all for your help. If anyone can post a picture of their pool (where the rope is anchored), I would be very greatful.
    Thanks again
    We have a vinyl liner pool and put our safety rope anchors into the coping above where the liner fits in. You can't tell from the photo, but the liner bead is well below where the anchor fits. The anchors are standard.
    We've only built our own pool, but I think you or your builder should be able to get a drill bit that will drill through the coping and into your decking material -- no holes in the liner.
    Dec 2005
    Thank you so much for the picture.
Closed Thread
  1. Restraining Rope
    By KentRock in forum Intex-type Pool Setup & Operations
    Last Post: 07-16-2012, 11:59 PM
  2. Automatic pool cover rope replacement
    By wec101 in forum Pool Equipment & Operations
    Last Post: 05-15-2011, 09:15 PM
  3. Pool rope/floats...
    By steveinaz in forum Pool Equipment & Operations
    Last Post: 03-21-2007, 11:14 AM
  4. Why not just use foam rope?
    By cbridges in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-24-2006, 06:55 PM
  5. Ye Olde Rope Float
    By KirstenHW in forum Pool Equipment & Operations
    Last Post: 07-20-2006, 12:54 PM
