Results 1 to 10 of 21
Thread: Oval Pool Set up with pics and tips?
    Default Re: Oval Pool Set up with pics and tips?
    Here is one I came up with. It is a 15 x 30 oval just before the wall was installed. It shows the side supports in place, the sand in the middle and the bottom rails leveled. On this model I install the pressure plates after the wall is up and before spreading the sand.
    Dennis
    In our area, the standard for the solid blocks is 4x8x16, the 3x6x14 are not available. Ask the local building supply about solid cinder/concrete blocks, they will direct you to what is available.
  1. oval pool with expandable liner
    By TismeTiffany in forum Above-Ground Pool Construction & Repair
    Last Post: 07-07-2012, 04:25 PM
  2. installing oval pool against house?
    By crafty1 in forum In-Ground Pool Construction and Repair
    Last Post: 06-29-2011, 05:46 PM
  3. Oval pool inground with deep end
    By hrsdennis in forum Above-Ground Pool Construction & Repair
    Last Post: 05-08-2007, 12:54 AM
  4. Do you wish you would have went with a different shape pool, round or oval?
    By daltrey in forum Above-Ground Pool Construction & Repair
    Last Post: 08-18-2006, 10:26 PM
  5. Oval Pool Installation
    Last Post: 07-23-2006, 01:35 AM
