Results 1 to 10 of 21
Thread: Oval Pool Set up with pics and tips?
    Dec 2005
    Lakewood, CO, USA.
    Default Are the round end blocks necessary
    I know I read that the patio blocks on the round ends aren't really necessary as there is really no downward pressure on the ends--just outward. We are ready to put the sides up and I need to know whether to stop everyone and go get some 12 x 12 or continue. Akkkkkkk!
    Hoskins, Nebraska
    Exclamation Use thicker/larger blocks for the sides!
    I would highly recommend to use the 12x12 blocks on the oval ends. They're cheap and keep the bottom boot of the pool cleaner too. I'm all for overkill when it comes to something you want to last 30+years!!
    You shouldn't be using 12x12 blocks on the sides where the buttress free uprights go - there is a thicker heavier duty block made: I believe they're approx. 3 inches thick x approx. 14 inches long- don't quote me, but close to there. Get the solid ones - not the ones with the holes in them. That is where your pressure lies- you need the heavier ones there. You can find them at Menards, Lowes - or wherever you bought the other ones from. If you look closely at one of my pics above - you'll see them and they are set back outside of the uprights as pictured.
    Sincerely,
    Donya (huskerfan)
    Hoskins, Nebraska
    Default blocks -
    Sorry - the blocks should be approx. 3inches thick x 6 or 7 inches wide x approx. 14 inches long. It's a standard size - there are no other sizes to choose from.
    Sincerely,
    Donya (huskerfan)
    Hoskins, Nebraska
    Default Re: Oval Pool Set up with pics and tips?
    You do realize the blocks will have to be set in the ground - so the top of them is level with the top of the ground, right?? It's going to take a little while to set them all - but I sure would do it- all the way around the pool, 12x12's on the oval ends, and solid 3x6x14's on the sides!
    Sincerely,
    Donya (huskerfan)
    Aranon is offline Registered+ Thread Analyst Aranon 0
    Thanks for the pics Donya (huskerfan). They really help. Waiting for my city permit to be approved before I start the electrical.
    Dec 2005
    Lakewood, CO, USA.
    Default buttress supports
    Too late on the sides, Huskerfan, they've been burried per specs for a week now. Our instruction manual required 12 x 12 along with crusher fines and said the round ends were optional since there is no downward pressure there, so that's what we ended up going with. Our soil is black clay that was professionally tamped. By the look and feel of it, I think we're going to be okay...maybe for only 20 years though.
    Shelley
    Here is one I came up with. It is a 15 x 30 oval just before the wall was installed. It shows the side supports in place, the sand in the middle and the bottom rails leveled. On this model I install the pressure plates after the wall is up and before spreading the sand.
    Dennis
  1. oval pool with expandable liner
    By TismeTiffany in forum Above-Ground Pool Construction & Repair
    Last Post: 07-07-2012, 05:25 PM
  2. installing oval pool against house?
    By crafty1 in forum In-Ground Pool Construction and Repair
    Last Post: 06-29-2011, 06:46 PM
  3. Oval pool inground with deep end
    By hrsdennis in forum Above-Ground Pool Construction & Repair
    Last Post: 05-08-2007, 01:54 AM
  4. Do you wish you would have went with a different shape pool, round or oval?
    By daltrey in forum Above-Ground Pool Construction & Repair
    Last Post: 08-18-2006, 11:26 PM
  5. Oval Pool Installation
    Last Post: 07-23-2006, 02:35 AM
