Re: Oval Pool Set up with pics and tips?
This sounds like good news. You saying that I just put my pool up on my Laser Leveled ground that I scraped with a tractor and blade and used mason sand to make perfectly level.
If I understand you right I set my rails on the level ground and I will set my buttress-less post on leveled concrete or patio stones. I will try and get the patio stones perfectly level and at the same height within and 1/8 of an inch of each other. I have a couple of lasers ( rotary and split-beam) and a transit.
After I set up my track and sides. I lay (cut to fit) my 2" Styrofoam Blue board. Stick my foam cove on it and put in my liner and it should line up with the beaded receiver track because it expects 2" of something under the liner within the walls. Correct? When do I put in the Gorilla Liner? Do I put it on top of the foam cove or under it. I am assuming I go in this order:
1. Leveling sand
2. Styrofoam
3. Gorilla Liner
4. Foam cove
5. Liner
6. Water
7. Margarita
8. Suntan Lotion
9. Sun glasses
10. Jump in
Does sound about right Dennis?
Thank you,
Aranon
