Results 1 to 8 of 8
Thread: Sand on bottom and water is dull (not sparkling)?
    Default Re: Follow up...
    Are you using plain, unscented bleach? Not the new and improved Clorox with the added ingredients? Any chance that it's either pollen from a nearby tree, or sand from nearby construction or dirt roads? Also you say that you've had the filter on bypass with no residue....when you added the bleach, did you switch it back to filter? That to me would still point toward a lateral problem.
    mjs31 is offline Registered+ Thread Analyst mjs31 0
    Texas
    Hi. Regular unscented bleach and I kept it in bypass. I am wondering if when I pour in the bleach it is bringing small particles to the bottom of the pool with it? May be pollen or something similar. Not quite sure what it is. I touch it with a brush and it dissapears, but it will come back.
  1. Red Pool is Now Sparkling
    By housejoe in forum Dealing with Algae & Slime
    Last Post: 01-16-2012, 09:14 AM
  2. Sand in Bottom of pool?
    By mysticgraces in forum Pool Equipment & Operations
    Last Post: 08-10-2006, 09:41 AM
  3. Sparkling water - how?
    By mshumack in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-05-2006, 06:53 PM
  4. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
