Results 1 to 8 of 8
Thread: I need vacuum (non automatic) help on hook up? What parts do I need and how.
    mjs31 is offline Registered+ Thread Analyst mjs31 0
    Texas
    Default I need vacuum (non automatic) help on hook up? What parts do I need and how.
    I cannot believe I need to ask this, but here goes. I have the pool buster and pool rover which work great, but I also want to get a regular pool vacuum. Here is my question. What do I need to get to hook things up? I can find the obvious vacuum heads and hoses, but do I need something to hook up to my skimmer as well or how does this work?
    I have a 24' above ground with sand filter.
    I am laughing at this, but I have never had to hook this style up.
    Smile Re: I need vacuum (non automatic) help on hook up? What parts do I need and how.
    Why be worried about asking a question about something you've never done?
    You can just put the vac hose into the suction port of the skimmer, but having the basket in place will catch the larger debris. Towards that end, there are plastic plates that can be attached to the vac hose to 'adapt' it to the skimmer and be able to leave the basket in place. Some vac hoses have one of the 'cuffs' that will swivel, attach that end to the vac head - if put in the skimmer it will suck air.
    I hope this helps, if you need more info, you know where to ask
    mbar's Avatar
    Ashland, PA
    Default Re: I need vacuum (non automatic) help on hook up? What parts do I need and how.
    Here is a link to show you what it looks like - you can find them at a pool store, or online
    http://www.a2zpoolsupply.com/more/57...Number-Marker/
    Northeast PA
    Texas
    Thanks for the info. I will look into this. I thought it was a vacuum issue I had, but turns out my sandfilter is the culprit. Looks like a busted lateral or something similar is causing sand to flow back in.
    Thumbs up Re: I need vacuum (non automatic) help on hook up? What parts do I need and how.
    If you need any help with getting the sand out or checking the laterals, all you need do is ask us
    Texas
    Me again. How would this listed adapter hook up? Looks like my Poolbuster battery will not charge so i am going to need to get a regular vacuum. I would imagine that most of these types of vacuums are about the same? Hopefully there is not a need to hook anything up to my return line since I have the Aqualuminator in place there.
    Thanks for your help
    Mike
    QUOTE=mbar;52940]Here is a link to show you what it looks like - you can find them at a pool store, or online
    http://www.a2zpoolsupply.com/more/57...Number-Marker/[/QUOTE]
    The adapter plate goes on top of the skimmer basket, vac hose attaches to that. The other end of the vac hose attaches to the vac head. No need to do anything with the return.
    Texas
    Thanks for the quick reply
    Quote Originally Posted by greenacres View Post
  1. Automatic Pool Vacuum
    By Pool2011 in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-11-2012, 11:35 PM
  2. and this is why i got a pro electrician to hook me up
    By tenax in forum In-Ground Pool Construction and Repair
    Last Post: 08-31-2006, 10:39 AM
  3. How do I hook up the vacuum?
    By court475 in forum Pool Equipment & Operations
    Last Post: 08-13-2006, 03:59 PM
  4. Excess Liner on J Hook installation Grrrr..
    By robot9000 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-16-2006, 10:14 PM
  5. AG Automatic Vacuum
    By savdoc2 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-04-2006, 05:16 PM
