Results 1 to 10 of 10
Thread: do you need to turn off SWG when adding chemicals
    Katy, TX
    Default Re: do you need to turn off SWG when adding chemicals
    Yeah, people who tell you to shock every 2-3 weeks without testing are idiots. If you don't have either of the problems I mentioned above, then there's simply no need to shock, other than to wear out your cell faster, or spend money on shock.
    How big is your pool?
    Michael
    La Quinta, CA
    jbirdy said: I also added salt, because my SWG read low salt after shock
    __________________________________________________ _______________
    Before adding salt you should double check your salt reading because the SWG read out my not be correct. I use test strips and also have a local pool store give me a read with their hand held guage. There will usually be some variance between test readings...but you should have a pretty good idea of the salt content by using all three readings.
  1. Proper order for adding Chemicals?
    By Dan-a in forum --cleanup--
    Last Post: 10-03-2012, 10:17 AM
  2. First time adding chemicals to 18x48 intex ultra frame pool..HELP!
    By babyblueiz77 in forum Intex-type Pool Setup & Operations
    Last Post: 07-10-2012, 10:15 PM
  3. Order of adding chemicals - question
    By rannrich in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-19-2012, 07:26 PM
  4. How long to wait to retest after adding chemicals?
    By mshumack in forum DPD-FAS based testing
    Last Post: 05-02-2006, 03:12 PM
  5. Adding Dry Chemicals
    By donfranko in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-23-2006, 07:27 PM
