Hi, welcome here!!![]()
The noise is usually because the gas/ air mixture is either too much or too little, which makes sense with what you describe. I would strongly suggest that you get your gas company out there to adjust it! If you want to do it yourself, I can tell you how to make the adjustment, but it wouldn't be the optimal/ safe way to do it![]()
), 1hp Starite pump
