Thread: adding another skimmer and return
    Aranon is offline Registered+ Thread Analyst Aranon 0
    Default adding another skimmer and return
    My pool comes with a Stainless steel panel for the skimmer and return. I thought about ordering another SS panel and adder another skimmer and return on the other end. Its 18' x 40'. Has anyone done this. Inground pools have several. My thinking is this would be better for the water. My pump is a 2-speed 1 1/2 hp Dymano by Pentair. Please advised.
    Thanks.
    Aranon
    Default Re: adding another skimmer and return
    Aranon, I have only seen dual skimmers on a couple of occasions. I saw a large Doughboy oval with a complete filter set up at each end once. Two systems to maintain seemed like way to much work for me.
    What I have seen done a lot is the addition of a second return near the far end of the pool. This is much easier to do. It only requires one line and the hole can be added with a 2” or 2 ½” hole saw. The second return will help your filter operate better and finish pushing the leaves and bugs back to the skimmer. I would try that first.
    Adding a second stainless steel panel would rquire cutting the wall and splicing the piece in. I would not recommend that.
    Best of luck, Dennis
    I'm with Dennis on this - a second return won't hurt at all.
    Kansas
    There are Floating Skimmers you can buy. I have seen a few different types on-line.
    Hey, did you ever get that clothes pin out from under your liner?
    ~Hoffmans
  1. Skimmer and return question.
    By errodr27 in forum Pool Equipment & Operations
    Last Post: 06-04-2007, 02:55 PM
  2. Need to plug return and skimmer for repairs
    By jstonemo in forum Above-Ground Pool Construction & Repair
    Last Post: 05-13-2007, 10:33 PM
  3. Adding Bleach w/CYA in skimmer?
    By JJParrish in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-07-2007, 04:46 PM
  4. Adding a return to an AG pool.
    By esalkin in forum In-Ground Pool Construction and Repair
    Last Post: 08-16-2006, 09:39 PM
  5. Adding bleach to the skimmer
    By trauh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-21-2006, 03:07 PM
