Thread: Auto level float valve.
    Scottsdale, Arizona
    Default Auto level float valve.
    I'm not sure what the part is called but I have an automatic water level system and the valve with the float attached to it is old and needs replaced. There appears to have been a run on this part around town. I can't locate one at any of the pool stores, hardware stores or home improvement stores I have visited recently ( it struck me as strange that Paddock, one of the largest pool builders in the area did not have one, what are they using for new builds ?? ) .
    Does anyone know of an on line supplier of these valves?
    Scottsdale, Arizona
    Default Re: Auto level float valve.
    I found one ...... thanks for all the help
    Keokuk, Iowa, United States.
    Glad to hear you found a float valve. Would you mind sharing more detail on where and what price? I would like to know and so might others.
    Scottsdale, Arizona
    ACE Hardware. I used one that is designed for a portable swamp cooler. $9.00 and it works fine.
  1. Mesiquito Larva and In-ground Auto-fill Valve
    By stuckpipe in forum Pool Equipment & Operations
    Last Post: 06-01-2013, 09:25 AM
  2. Float for a 2 year old
    By jilted in forum Pool Equipment & Operations
    Last Post: 05-14-2012, 08:25 PM
  3. use of main drain with skimmer float
    By byron366 in forum In-Ground Pool Construction and Repair
    Last Post: 06-15-2011, 09:45 PM
  4. Ye Olde Rope Float
    By KirstenHW in forum Pool Equipment & Operations
    Last Post: 07-20-2006, 12:54 PM
  5. does dead algae sink or float
    By mspool in forum Dealing with Algae & Slime
    Last Post: 05-30-2006, 10:57 PM
