Results 1 to 3 of 3
Thread: Pool Volume
    Default Pool Volume
    My pump, Pinnacle 1.5hp uprated, needs replacing and I have been fairly sure that it as well as my DE filter, 36 sq ft have been woefully too small for my pool. I have an Infinity Lazy L - 18' x 34' x 43' (3.5 to 8 ft deep) http://internationalswimmingpools.com/port_stock.html
    Does anyone have a ballpark idea of the volume? The equipment I'm using suggest 24,000 gallons, but I suspect that is way off.
    Default Re: Pool Volume
    Quote Originally Posted by isdsms View Post
    My pool is hopper-shaped, 18 x 36, with the same 3.5-8 ft deep, and it contains 29K gallons.
    Ontario.
    The 1.5 hp is probably plenty, this link for the main pages goes over the pump size. Usually a pump is sized plenty big but the filter will be off.
    http://www.poolsolutions.com/tips/tip83.html
    If that is a link to the company that installed the pool, have your tried asking them the volume. Otherwise, it's a case of diagramming and measuring the depths in your pool to get an idea.
    You can also search the forum on 2-speed pumps, which are recommended to help electric bills.
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
  1. Pool Volume Estimator
    By AnnaK in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-29-2011, 10:08 AM
  2. Determining pool volume
    By KirstenHW in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-19-2006, 11:50 PM
  3. h2o volume of my pool?
    By dhale63 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-11-2006, 01:56 PM
