Thread: New indoor pool - what kind of heating?
    Rbrenton is offline ** No working email address ** Rbrenton 0
    Default New indoor pool - what kind of heating?
    Friend is in final stages of planning for a new indoor fiberglass setup. The install contractor stated that a true gas heater isn't required, as he can make use of a heat pump instead.
    My question is, is that correct? Any recommendations on brand or type? Is a heater needed at all?
    Indiana.
    Default Re: New indoor pool - what kind of heating?
    Quote Originally Posted by Rbrenton View Post
    He'll no doubt want a heater. The pool won't get any solar gain, so it will be cold otherwise. A heat pump is an excellent choice. He might also consider solar panels on the roof over the pool if the climate is appropriate. They are cheap heat.
    Is a heat pump the same thing as a heat exchanger? I'm not sure how these work.
    You can think of a heatpump as a central airconditioner running in reverse. An airconditioner absorbs heat from the room and dumps it outside, hence cooling the room. A heat pump absorbs heat from the outside air and dumps it into the pool, thereby heating the pool. They typically have a COP of about 5-6 which means for each unit of electricity you put in you get 5 to 6 units of heat out. Much more economical than gas or propane heat.
  1. SWCG and Indoor Pool
    By codyt in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-21-2013, 02:36 PM
  2. Indoor pool - high PH
    By cchase009 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-09-2012, 01:46 AM
  3. Indoor Pool in NJ
    By joe8100 in forum In-Ground Pool Construction and Repair
    Last Post: 03-26-2007, 06:28 PM
  4. What kind of pool sweep to use??
    By dacslow in forum Pool Equipment & Operations
    Last Post: 05-25-2006, 11:35 AM
