I have an aquarite swg and the manufacturer reccomends a cya of 80-100!
I live in South Florida. I have owned my first pool for 6 years now. 12,200 gal. with exposed aggregate finish, spa with spill over, cartridge filter, pop up bottom cleaning jets, Chlorine by swg. I am eternally grateful for The Pool Forum!!
15'x30' Rectangle w/ ovals at ends 12.2K gal IG pool; Bleach now as SWCG died.; Hayward 1200 cartridge filter; Emerson 2HP pump; 6hrs; Taylor K-2006 La Motte Borate Test Strips; utility; summer: ; winter: ; iPad; PF:9.8
I'm not sure of the chemistry behind it, but that's correct with SWG manufacturers... 60 - 80 ppm for Pool Pilot and chlorine levels at about 3 ppm is more than sufficient to maintain your pool crystal clear. All other water chemistry parameters considered to ensure proper water balance (Saturation Index).
Most commercial guidelines recommend 100 ppm as the maximum stabilizer level allowable in a public pool.
Sean Assam
e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
In light of recent studies down I would set an upper limit of 100 ppm for a plaster pool since it has been suggested that higher levels can cause damage to the plaster surface. Remeber that any aggragate finish (DiamondBrite, etc.) is actually plaster
