Thread: Pump problem
    Illinois
    Default Pump problem
    I found my pump not working last Friday. I reset all the electrical and tried to turn on the filter. It makes a groaning sound for about 3 seconds and then nothing. The pump is a Jacuzzi Magnetek 2HP (1.10 SF 2 SPD). I have a 30,000 gallon in ground pool with 500 gallon attached spa. Should I just order a new pump from an online pool store or is there something else I can check? Thank you.
    DFW Texas
    Default Re: Pump problem
    Sounds like what mine did a few weeks ago. Ran for a minute (making a racket) and then tripped the breaker. I think a bearing went out, so I just replaced it. I have a 2HP too and figured a new (more efficient) motor couldn't hurt.
    IG concrete, 16K gallon, DE, BBB, Polaris 360
    Illinois
    So you just replaced the motor and not the pump? Did you do it yourself? Which one did you get?
    DFW Texas
    Quote Originally Posted by ksturge View Post
    Correct. It's not hard to remove the motor (or shouldn't be). Turn the breaker off and remove the motor from the pump. You'll have to disco the electrical connections and ground from the motor as well. Mine is a square flange, so there are only 4 bolts holding the motor to the pump.
    I took my old motor to my LPS and he matched a new one for me. He removed my impeller as well and transferred everything to the new one. There's also a pump seal that should be replaced at this time. I went to my local Leslie's and got a high-efficiency Emerson motor.
  1. New pump problem
    By rayh78 in forum Pool Equipment & Operations
    Last Post: 06-17-2007, 01:22 PM
  2. Pump Problem
    By ellry99 in forum Pool Equipment & Operations
    Last Post: 06-13-2007, 08:32 AM
  3. Do I need a new pump, air problem
    Last Post: 05-08-2007, 02:25 PM
  4. Help with Pump Problem
    By Ctxman in forum Pool Equipment & Operations
    Last Post: 12-31-2006, 12:40 PM
  5. Pump Problem
    By RENOPOOL in forum In-Ground Pool Construction and Repair
    Last Post: 10-03-2006, 12:33 PM
