Thread: Calcium Deposits on Brick Coping/Mortar
    Houston
    Question Calcium Deposits on Brick Coping/Mortar
    How do I remove Calcium deposits on Brick Coping/Mortar? I have small thin white lines developing on my mortar between brick coping. Also have a white film on brick coping by tanning ledge. Pool is 15k gals I/G white plaster finish, with SWG. Pool water chemicals are okay from local pool supply store as of yesterday. I have tried pumice stone with pool supply recommended cleaner to no avail.
    Any suggestions are appreciated.
    Default Re: Calcium Deposits on Brick Coping/Mortar
    Did you ever get a reply to this? I've got the same problem and have been using acid to wash it away, but that creates a constant battle with the ph.
  1. Mortar in the pool after setting coping stones
    By krdowns in forum In-Ground Pool Construction and Repair
    Last Post: 08-28-2012, 10:33 PM
  2. Identifying the grout/caulk between brick patio and coping
    By Ian Rob in forum In-Ground Pool Construction and Repair
    Last Post: 06-23-2010, 10:13 PM
  3. Calcium deposits?
    By halefmly in forum Dealing with Alkalinity and Calcium
    Last Post: 11-11-2006, 11:26 PM
  4. coping brick leeched into grout
    By the_scum1 in forum In-Ground Pool Construction and Repair
    Last Post: 07-12-2006, 08:54 PM
  5. Question about grout between brick coping
    By putter in forum In-Ground Pool Construction and Repair
    Last Post: 03-27-2006, 09:13 AM
