Thread: New surface still needs daily acid
    Southern CA
    Default New surface still needs daily acid
    We have an IG gunite 13,000 gal pool, which was resurfaced in Feb with a quartz-type surface. The pool guy handle chemistry for the first month and then I took over again.
    I have been fighting high pH ever since and need to add acid almost daily. I don't have all my numbers in front of me, but
    ALK is ~ 110
    CH is ~ 150 ( our water is hard)
    I am trying to understand if I have a chemistry issue or this is normal for the first year of a new surface.
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Default Re: New surface still needs daily acid
    FWIW, my IG is 5 months old (gunnite/plaster) and I still battle high ph, though it is lessening. Typically I need to add about 2.5 cups of muriatic acid every 3 days or so...my numbers typically look like this:
    FC=7.5ppm
    CC=0
    PH=7.8
    CYA=55ppm
    CH=375ppm
    TA=120ppm
    My TA was 210ppm at filling, so it is making its way down.
  1. Wet Edge Luna Quartz 'Mediterranean Blue' pool surface stained by acid
    By dbhutch in forum In-Ground Pool Construction and Repair
    Last Post: 07-30-2011, 10:33 AM
  2. How many PPM of Chlorine should I lose daily?
    By keithw in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-10-2006, 05:06 PM
  3. Using Bleach as daily chlorine
    By golfwig in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-06-2006, 03:29 PM
  4. SW cell needs daily cleaning
    By poolaris in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2006, 06:57 PM
  5. How long to run filter daily?
    By famdog in forum Above-Ground Pool Construction & Repair
    Last Post: 06-06-2006, 01:01 PM
