Sean…
Can you give more detail to “cooler water temperatures” please? I live in Southern Calif, where it does not get what some would determine cold. Last year, the coldest I saw my pool get was about 55 degrees. I never reduced my output (Aqua Rite System) to zero, or turned it off. I did however turn the dial down to about 40%. I did see (if I remember) the digital readout on the system say “cold” (again if I remember correctly) but most days, no matter the day of the year, It was generating to the standard 2800 (+/-) every day.
Should I be zeroing out the output and adding chlorine – for my weather, or am I not considered cold-cold weather? My pool always had plenty of chlorine obviously, as the water remained crystal clear all year, even in the coldest months. I read about “winterizing” or “closing” the pool during the winter months, but I never did.
Still learning…..
-Mike
