Thread: Fix Wrinkles - Now or Later
    jrv331 is offline Registered+ Thread Analyst jrv331 0
    Default Fix Wrinkles - Now or Later
    I have several wrinkles in my liner that I want to fix. Im getting ready to close my pool, so is it better to wail till next year or do it now before closing?
    John
    Omaha, Nebraska
    Default Re: Fix Wrinkles - Now or Later
    If it were me, I would fix them sooner rather than later. I had several wrinkles that I let go, then found that the sun and chlorine had faded the liner in those spots, so I had line marks that were created and noticeable after the liner was stretched out.
    Jean
    __________________________________________
    20 x 40 33,000 gallon vinyl liner inground, Nebraska
    I had two bad wrinkles in the shallow end for two years. One of them was a section that stood up about an inch above the bottom of the pool. Two weeks ago we go heavy rains and the pool filled above the bead. The water behind the liner lifted it enough I was able to smooth everything out. I have a dry well under the deep end of the pool that can valve into the main pump. I set it to pump to waste and pump the sump out. Ever since then the liner is perfect again.
    Thumbs up Re: Fix Wrinkles - Now or Later
    John, the sooner you correct the wrinkles, the better. The liner will 'learn & remember' where the wrinkles were - thereby making it harder to fix it later on.
  1. wrinkles
    By bobert in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2011, 03:06 PM
  2. Wrinkles
    By korinian in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-30-2008, 11:48 AM
  3. Wrinkles in my deep end...
    By seadogg in forum Above-Ground Pool Construction & Repair
    Last Post: 05-21-2008, 02:24 AM
  4. Fixing Wrinkles
    By jrv331 in forum In-Ground Pool Construction and Repair
    Last Post: 05-01-2008, 08:19 PM
  5. oh no! WRINKLES
    By RavenNS in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-29-2007, 09:26 PM
